And does that disable your router?
Nope? You're just opting out of that service.
Im having problems with Battlefield Bad Company 2 still.
Sometimes it finds servers other times it says it fails to connect.
I suspect it my BT equipemnt thats at fault.
Im looking in to forwarding ports.
But I wanted to make them as tight as possible, I only need to specify these:
18390 TCP Outgoing
18395 TCP Outgoing
18395 UDP Outgoing
13505 TCP Outgoing
80 TCP Outgoing
But on the hub, it looks like when you specify the port, you not specifying which way, I think its both outgoing and incoming.
Its fine if it works I suppose, but is this a security risk?
I do have software firewalls on all the machines too.
Also as a side not, BT throttling software must be crap.
My speeds downloading from ATI driversite are max. from Nvidia they are current 12Kb!
Iv seen the same shizzle from the Adobe website too.
They should sort this out for god sake!
No probs here. (ADSL24 FTTC & WNDR3700)
@Locky: I actually really like it, but i have always liked Netgear routers. Had a DG534GT, with DGTeam FW before this.
I did also by the Buffalo WZR-HP-G300NH, which is good too, (Can run DD-WRT) but the netgear won in the end so i sent the Buffalo back.
Ope: Its more likely the HH tbh.![]()
Iv tried everything in the home hub.
Port forwarding, disable the firewall, diabling upnp a combination of these, nothing worked.
This issue has opnly started happening in the last week. It stopped working for 2 days, came back out of now where, and now its stopped again.
exact same here, and some for my mate too.
Locky, Im going to call BT and ask to speak to the technical department.
If you do the same, then our voice gets bigger.
Im sure we are not the only ones with these issue.
It makes sense that it is BT ****ing around with their throttling....
NOTHING has changed on my system and one day it works the next it doesnt.
Even in the same gaming session, it can go from working to not working.
