320kb/s or WAV are a waste of space
I DJ however and can safely say anything less than 320kbps is completely unsuitable for a club sound system. However the op could probably get away with 192kbps im sure![]()
So do I, and that's really not correct. Amongst DJ's everybody goes on about "320's" the whole time but that's generally a lack of knowing about the formats as you lose nothing with v0, it gives all the bitrate required but only where it's required. Some of the first CDJ's to support MP3 would only do CBR but that's ancient history now.
I've gone from 320 to lossless, back to 320 and now v0 for my sets. Club sound system aren't built for precise listening, they're made for loudness. Imperceptible difference between the three, it's only when you properly starve or limit the bitrate that you have problems.
Interesting reading mate. I know of a club in Belfast (which I won't name) and the resident DJ insists that nothing below 320kbps is played on their sound system. He's a tool right enough so that may explain it![]()
That's not really true. It's an effective method of compression, but it's still lossy compression and will lose fidelity. Whether you can hear the difference in a particular circumstance is another matter entirely!
For ripping from CDs for computer playback, I would use FLAC or a similar lossless format. Whilst this uses more disk space, large hard drives are now so cheap that I don't see how it really matters. If an average FLAC album uses about 400MB, you could fit 2500 albums on a 1TB hard drive, which you can get for £30.
