No POST beeps (no speaker)
18 Oct 2002
Brighton
Hi,
I have a Gigabyte GA-P35C-DS3R that appears to have become faulty. The PC turned itself off randomly and abruptly yesterday, restarted OK but refuses to work today.
When I turn it on, the power light comes on but nothing more happens. I tried a spare PSU and nothing changed so that is OK. I have disconnected everything to try to eliminate the problem without any success.
It therefore seems to be either the motherboard or the graphics card but, without a spare graphics card to test, I was hoping to get some beep codes to help me. Problem is, my case doesn't have an internal speaker so I'm a bit snookered!
Apart from randomly replacing the graphics card or motherboard, my only solution is to try to hook up a speaker from somewhere. Any thoughts on how I'd do this or any other suggestions?
Many thanks.
Hi mate, have you tried removing the battery of your motherboard for about 10 mins to clear the CMOS? If you havn't still, I'd try that.
Also, try removing your card and re-inserting it back to the pcie slot.
I've tried both but I only removed battery for about 1 minute. I'll try again...
If the battery was dead, would that prevent the PC from working as described above? Surely I'd still get a picture on the monitor.
Sometimes the beeps do but I think it's motherboard dependent. I meant just to use the little square socket terminals from one of the frontpanel connectors (in the process destroying one) to get the speaker connected. You could hold the bare wires on the relevant pins on the motherboard but that leaves you in a tricky position to fault find.
Ta. I'll see what I can do.
