Why does LINX make the cpu run so hot?
7 Aug 2004
As title, im curious, prime or intel heat test gets to about 62, but I fired up linx and it got to 78 :eek: :(, having to lower my overclock and reduce volts as much as poss, was running 4.05ghz now 3.9ghz, not a massive drop but id rather have stability.
Because it's highly efficient and loads more of the processor, when running games etc there is still a lot of the processor which is idle.
I always test my overclocks with Linx or Prime95, would rather have the slower speed 100% stable than get 200mhz extra and be running a time bomb.
I'm finding more and more while Linx/IBT etc.. are good indicators, a good 24hr prime is better, i've had cpus pass 50-100 runs of IBT and fail prime within minutes..
interesting, im doing both I think on this CPU, its a weird one, 4ghz it gets to 78, 3.86ghz where im at now is 66c, however thats the 'CPU' temp in CPUID Hardware monitor, however the 'core temps' listed 1-6 under the tab AMD Phenom II X6 1055T all list temps at 46-47c, so im not sure what temp sensor I should be reading here, whats the critical temp ? the 6 individual core temps or the 'general' cpu temp, which is now 68c.
i know some temp readers have trouble reading AMD processors. the recommended limit for all AMD processors is 62C, so i think i would ignore the one that reads it at 78C because the chip would have throttled back WAY before then. i think it throttles back at ~65-70C
In my experience temperature monitoring on AMD's is still not very reliable, it's even listed as a known bug:
If it's stable and not throttling or anything then I wouldn't worry too much about the temperature reading.
That's a worry off my mind then, my B55 has been showing around 72 degrees at 3.8GHz (1.46V) but yes, you'd think the processor would throttle itself if it was at dangerous levels.
Hmm this is concerning, how will it throttle itself though if it cannot get an accurate temp reading? I'm currently trying to get both prime and linx stable. I started by decreasing the clock speed down to 3.8 and decreasing the voltage to 1.39v, now I'm slowly increasing the volts until it's 3.8 stable, and then increasing the clock speed in small steps until a reasonable ghzVSvolts balance is found.
What's the max volts again for a 95watt 1055t? Heatsink is a silver arrow, temps read 70c on 'cpu' 48c now across the 6 cores, is the latter likely to be the real temp?
95W does 71c as its safe temp. Older CPU's used to throttle at like 68c, like my old 125W 1055T.
It's the CPU temp that should be listened to lol.
It's my old chip, at 4.375GHZ I only hit 59c under a 120.2 RAD.
Here ;
Core temps were ~40c
Here ;
Hey dude :D , hmm wonder if the silver arrow just isn't good enough then, should be good though ? 4ghz as said hits 78c, but it doesn't throttle at that temp so is it an accurate reading ? The core temp is at 47-48 there though ?
I don't know why you're hitting so high hmm.
Core temp doesn't mean much at all, I think on that chip the calibration was off 20c+.
On a T.R.U.E Rev C in Winter I hit 4050MHZ stable on a 125W chip under 60c.
Hmm proper proper confused now, the silver arrow is bolted on to its limits, i.e. the screws wont turn any more so its defo in good contact, using arctic silver 5, is it the 16gb of ram heating up the chips mem controller perhaps ? so my 78c is accurate then Martin? its obviously not that high now as iv throttled back, hmm ill replace the fan 'back and above' the heatsink tonight when I get home from work, its only a quiet 'silent' one, ill get one with more beefy airflow.
If that doesn't work I suppose I Could look at water cooling, get a 120.3 radiator and a pump/cpu block/tubing of your recommendation?
78c I'd wager could be accurate, I never saw my chip throttle, but I could never get it passed 70c anyway due to my 120.2
4 DIMM's could be causing strain on the IMC, but I'm not sure how much that would affect the temperature, could always try with only 2 DIMM's like.
Yeah, also below the heatsink is the 4 dimms and the cpu socket which is all 'boxed in' due to those componants, so little air flow is happening, I may switch to water for better cooling and an 'open' socket and dimm area with which I can hover a 120mm fan over to keep excellent air flow
got it linx and prime stable at 3.85ghz, 75c in linx after 12 hours, managed prime for 10 hours and got 69c.
Proper somethings up given the normal temps what a silver arrow can manage usually, I have no clue what it is though, im 99.9% certain its bolted down properly, I think ill try reseating it tonight.
Granted the PC is in a large loft cupboard, but its well ventilated and never effected temps really on previous builds iv had.
I thought LLC was meant to stabilise the voltage, not increase it?
I wish I could answer you.
To stabilise it, it increases it.... Which is stupid... Lets say you need 1.5v constant for 4GHZ, you could BSOD at anything less, but setting 1.5v will boost it up more in stress.
On my old Gigabyte board, 1.5v was 1.5v and that was it.
What's the Vcore under load?
LLC can boot it up like 0.06v more, which is quite a lot. can take it up an extra 10c.
I think its between 1.44-1.46, but im at work so will have to check later
I thought LLC was meant to stabilize the voltage, not increase it?
Yeah it does stabilize the system, but in doing so it can and does feed more power to the CPU to keep it stable.
Right, so am I better off keeping my LLC at Auto or should I bump it up to 100% (my Asus board presents the LLC in percentages...) and lower the actual vcore a notch? I need 1.46V to get mine stable at 3.8GHz, at which point I'm already reading temperatures of ~72c. Will get an H60/H100 later on, but for now... yeah. :)
