Spec:
i5 2500k
MSI GD65 (BIOS v1.11 20/4/2011 with optimised defaults loaded, only things changed are SATA Mode -> RAID+Hotswap & CPU Cooler fan speed management on)
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel RAM
Having never overclocked before I thought I'd give it a go as the MSI GD65 has the OC Genie button. However when I activated it my computer just went into a reboot cycle until I turned it off again
After a bit of searching it seems its most likely down to the memory. After looking at the memory it seems that both sticks don't show up the same in MSI control centre/CPU-Z.
As you can see they not only have different part numbers but different timings, is this likely to be causing the problem with OC Genie?
Would just putting the multiplier at x42 be better than using OC Genie or do I need to mess around with changing voltages too? I'm not looking to push it as hard as possible, just give it an easy boost.
i5 2500k
