This happened once a month or so back, where i had to try multiple times before the computer would get to the bios post screen (everything powering up, just no post beep or screen etc)
A couple days ago i flashed my BIOS, and now it's happening all the time. It happens when turning computer on, or even if computer is suspended and resumed; occasionally it will post first time in a normal amount of time, but sometimes it can take me up to 10 minutes of waiting a while to check if it eventually posts, and then forcing it to power down and turning it on again until it posts.
ONCE it posts, computer is perfectly fine and shows no negative symptoms, running (Aslong as i don't suspend it) for +10 hours (never tried longer).
Any ideas?
Any ideas?
