- 20 Jul 2009
- Midlands
Hello!
Another tasty little competition for you to get your hands in to!
MSI and OcUK are offering forum members a chance to win themselves a MSI N560GTX-Ti Twin Frozr II/OC Graphics card.
The MSI N560GTX-Ti Twin Frozr II graphics card features the advanced Twin Frozr II Thermal Design. To decrease operating temperatures by up to 20°C, MSI has integrated it’s engineering expertise to create the Best Thermal Design. The GPU area is covered with a large surface area heat sink with a copper base, ensuring the best possible contact surface with the GPU. Surrounding components like Memory and PWM components are covered by a large unibody heat sink mold. With heat pipes with MSI’s SuperPipe technology, excess heat is transferred quickly to a high density Aluminium cooling fin grid. The low-noise fan setup, which incorporates a two 8cm fan setup, are temperature controlled by PWM, ensuring excellent air flow to all parts of the Twin Frozr II Thermal Design while reducing sound levels up to 8.4dB.
MSI’s Exclusive Afterburner Overclocking Utility
MSI’s exclusive Afterburner Overclocking utility allows for flexible overclocking and monitoring options. MSI Afterburner allows for instant adjustment of the GPU Frequency and GPU voltages, thanks to its unique Ultra-Voltage function, a combination that allows for more headroom for overclocking. The advanced fan control function allows end-user control of fan speeds to ensure stability when required or low noise when needed. By storing up to five different fan profiles, users can quickly switch between their profiles to fit any situation. MSI Afterburner also displays a wealth of information about the card like real-time temperatures, speeds, voltages, load levels, allowing users excellent supervision over their card while benchmark for Best stability with MSI Kombustor.
MSI Quality: Military Class II
MSI created Military Class II to provide the best stability and quality whether it's for desktop work, games or overclocking. MSI's Military Class II products are built using Military Class Components to ensure the highest stability under every circumstance.
All MSI Military Class II products are built around three key components:
Hi-c CAP - Extreme Thermal Stability, Ultra-low leakage and Self-recovery Mechanism
SFC (Super Ferrite Chokes) - 30% Higher Current Capacity, 10% Better Power Efficiency
Solid CAP - 12+ Years Long Lifetime - Lower Temperatures - High Stability
To stand a chance of winning a MSI N560GTX-Ti Twin Frozr II OC just answer the following questions correctly
Q1 - Which of these is NOT a feature of the Twin Frozr II Cooler?
A) Dual 8CM Fans
B) Nickel Plated Copper Base
C) Superpipe Heatpipe Technology
D) Plastic Fan Shroud
Q2 - Which of these is NOT a feature of Military Class II?
A) Liquid Capacitor
B) Super Ferrite Choke
C) Hi-C Capacitor
D) Solid Capaictor
Q3 - Which of the following features are part of the N560 GTX Ti?
A) DirectX11 Support
B) 3D Vision Support
C) Physx Support
D) All Of The Above
All correct entries will be entered into a draw to win the 1st prize : one MSI N560GTX-Ti Twin Frozr II OC Graphics card.
Ten Runners Up will receive a free copy of Lara Croft : Guardian of Light
* Answers to be submitted to Scottib via the forum TRUST email system
* All correct submissions will be entered into a random prize draw
* Any user providing answers via this or any other thread will have their entry disqualified and may find themselves subject to suspension from the forum
* Closing Date For Entries : Friday 24th June
* The winner will be announced here shortly after the closing date
* MSI reserve the right to change or withdraw this competition at any time
* There is no cash alternative for the prize offered
* Competition is only open to UK resident members of the OcUK forum
* One entry per member per address
A) Dual 8CM Fans
A) Liquid Capacitor
C) Hi-C Capacitor
D) Solid Capaictor
C) Physx Support
D) All Of The Above
