Got my M4's today ..can only fit the front as the rear hose is slightly too short even though i thought it would be fine.
Is it possible to to just replace the hose and use the original fittings?
I prefer the spec of the new N'dee, although i dont have the money for either of them, just bought a new car as well so im a bit skint this month and next.
Steerer should be long enough i had a few spacers on my old frame so at worst might need a smaller stem.
Edit: Looks like the headtube length is 129mm opposed to my last frames 120mm so minus the spacers should be fine.
Its listed as N'Dee here, http://www.biketart.com/collections/forks-suspension/products/bos-ndee
They might have some left over stock of the N'dee but they will be replaced eventually with the above Idylle.
Do you really want a fixed 180mm fork on the Nomad?
haha, I'm gonna start selling single pedals on the bay.
Yes, im putting my marzzochi 66 rc3 on they will easily fit after looking at the sizes.
I guess Vanessa's point was not about whether it will fit or not or whether it will take a 180mm fork, but whether you want to turn your bike into a Mini DH bike, opposed to an AM/trail bike
Who are you to tell me what i can do with my money and what bike/components i should use. You can offer your advice by all means but dont impose your views on me like there law.
