Anyway ichabod crane how did you go about putting the bike tape stuff on, did you use the soapy water method?
That's the only way to do it.. in fact you MUST do it that way and no other way
http://vimeo.com/11849788
Who are you to tell me what i can do with my money and what bike/components i should use. You can offer your advice by all means but dont impose your views on me like there law.
Yep, soapy water, library card, hair dryer and a scalpel![]()
This will be one of the finishing touches on my 456.
Is it really as good as people say? I mean, some tape can protect against stones?![]()
Talking of tape, my cables are beginning to rub but my frame is anodised, I've tried some of those frame patches but nothing seems to stick, it's almost like Cube decided to coat it in Teflon or something, any suggestions?
holy crap I can talk a lot of sh!t
There is a clip on it you need to remove then the bolt comes off.
