If I've understood correctly and worked it out right, that should give a height of 34 blocks and a span of 2x43 for the total arch.
It looks like the last two lot of 6's at the top meet, so giving a line of 12. Should the bottom set of two blocks touch, at your level of 7 above sea, giving a line of 4? If those numbers are right it might help with laying out some markers along the floor.
Also what's the deal with the torches at the moment? Are the just temporary for now? Not going to slap them down too randomly but inside the bridge there seem to be 6 blocks between each one, on the top of the bridge they seem a bit more random. Only counted between a few of the last ones and the seem to be anywhere from 10 to 13 blocks apart.
I've added some to it already tonight, just on here while the server restarts but not found a rhythm yet so finding it slow going at the mo. :/
edit: well didn't get as much done as I planned, found the arch slow going.but managed to get a bit done. Looks like you have been leaving 5 blocks between the bottom of the arches, so I finished off half of one that was there are and put the beginnings of the next one. Think it is ok but was getting dark in game and I need to go to bed now. Any way have a look and let me know if ok or not. Left some cobble for you as well.
Thanks, abit confused with the numbers lol
The torches are abit random, that'll have to be fixed.
Probably going to have to build some large meaty tower at the end of the bridge with seperating lanes that go down to the ground in some way because it appears there is no mountain range
It is a damn long way as well!
