Max'd out 5850 & 5870?
16 Jun 2011
Can someone direct me maybe to both cards with water cooling setup? i was wondering if the 5850 can still do 5870 speeds when on water cooling. 5850 is looking an excellent card for ££££
A 5850 can do 5870 speeds on air, you may need to adjust voltage though.
Yes, i know that one. My mate as a 5850 nearly matching my 5870 with little volt mod. Got mine to 930. Im just thinking to get the extra under water you may need the 5870 as the 5850 may start failing earlier due to less shders and already OC'd to match 5870 :)
Headroom basically, is it better on the 5870 making it worth the extra £££ :)
Original V1 revisions seem to clock better, my sapphire 5850 does 850/1200 on air with no voltage tweak and runs quiet at full load, the Sapphire Extreme HD5850 hits this usually with the TRIXX utility you can download,
Yes, got that. Only one that bloody works :)
I cant up the voltage on my 2 5870's though so 930 is max safe. Any ideas on what that could be. Nothing in my bios or nothing for voltage to pci-e :(
