I want to replace my case so I can make it a bit tidier.
Preferably I would like the ability to run cables behind the motherboard, disks inserted from the side and access to eSata and SATA 3 on the outside. It needs to be large enough to hold two GTX 480's. I use one SSD and two Raptors with a couple of optical drives. I would also like to fit a hot swap cage for HDD's.
I've looked at the NZXT Phantom but it has a door over the optical drives and the Corsair Graphite 600T.
Any help would be appreciated.
Andi.
Andi.
water all over the PSU!! (luckily it was covered).
