Thank you for your reply managed in the end by cutting top cable tie and that loosened the cables. looking at the pic have you put the hop swop bay at the top, thanking you in advance regards
Thank you Ceeecooo for your reply, have you changed the position of your hot swop bay to the top of the case, and is there an advantage? thanks in advance, regards
I see, sorry to be nosebag," what fan controller are you using"? If you don`t mind me asking. on my prevoius rig had a zalman which also monitors power used but, it has proved to be less than adequate. Thanking you in advance regards
Thank you Cleeecooo for your reply, I will purchase it, still undecided as to optical drive and to getting a second gpu, but thanks again regerds
Thank you, no am using 990x, rampage 3 black, hd5970, h7o cooler and 250gb series 510 elmcrest. also changed the fans to apache black, gave old rig to grandson, regards
Thanks for reply, getting on now pobably last personal rig i will put together ah. Cleeecooo you seem to have a great deal of knowledge and no I never creep, just try to be as polite as possible. a friend of mine told me today change ide over to ahci because i am fitting the 510 series. sorry to be a pain thanking you in advance regards
