- 6 Jun 2010
When i launch the game it detects my card as 750mb and setting itself to low spec, any idea's?
I've just started the 1st game everything was going great until I got up to the point where you go through a really long cut scene and then throws you into a boss fight where I seem to die pretty easy and then have to go through the cut scene again. This is getting really annoying and was wondering if its like that for the rest of the game and like this in the second?
Yeah im finding that i have to drop it down to easy for some fights. But then it becomes to easy lol No middle ground.
I can only seem to run this at 20-30FPS on my AMD Phenom X4 3.2Ghz, 4GB, 4850 1GB. Is the GFX card letting me down?![]()
I've decided it has the same learning curve as Demon's Souls, or it would if it didn't have difficulty settings, you just get used to the combat after a while to the point where everything becomes a lot easier, it doesn't quite have the balance of Demon's Souls and can on occasion be rather unfair however once you get into the combat and figure out timings and mechanics everything starts to flow together.
Just got this game and I set it to the high preset to start off but dunno what to turn down to help with fps because it aint that great right now what would you suggest?
Right just downloaded this game, but I've managed to loose my saves from the original game due to a re-install of my system.
Is there anyway to recreate my choices from the first game to import them into the second? and do they really change the game that much?
No advice? I don't want to start the game until I have my previous decisions (if they matter and it is possible to do so)
So it doesn't matter that I ****ed of triss after romancing her, saved alvin and the witch, got that knight to the leader of the group etc..?
