Cheers all.
Been out tinkering, and have made a totally definitive list of faults that are annoying me already. This one will be perfect and for minimal cost, too.
- Clutch pedal rattled and squeaked, turns out the mounting bolts on the master cylinder were loose. Quality clutch replacement in January, then.
- Rear passenger door didn't open with central locking - new actuator fitted, which was given to me with the car.
- Front passenger door sometimes doesn't open with central locking, currently fitting this but came in for a brew.
- Could do with an oil change, although it was done recently it's done a good few miles since then.
- Clutch pedal was soft at the top, system bled and it now feels much better.
- Radiator mounting bracket was fractured, new one fabricated this afternoon.
- The lower coolant rail is corroded to ****, so I've made a new one from copper. The Rover one is made of steel, and costs £35 and they're hard to find to boot. Will get pictures of the replacement up soon, need to fit this also.
All minor things, but they've been annoying me somewhat. Not bad for a £995 car though, everything else works 100%.
We also test fitted a cheap 'cone' type induction kit, and wow... what a noise. Think I nearly wet myself when it got above 5k, amazing!
