Nice, nice!
How much did you splash btw? I'm due to buy the 8-16mm Sigma for my 40D and will go all out crazy with that lol so expect pics in the coming weeks
£690 for the 5D (would have bought a cheaper one but needed one for a gig this coming week and couldn't wait much longer), £305 for the 50mm from calumet (would have bought second hand but I had a voucher burning a hole in my pocket and with how much use I'll get out of it, it was worth going new.
Let me know what you think, any comments appreciated. All the photos are straight form cam and untouched with any photo editing software.Ah that's excellent, is it the mkII? I'm going to be in the same boat next month and I am undecided on 60D/5D or 7D although the 7D is considerably more expensive it would be an investment although a use 5D would not get a frown although I'd miss the 7.8fps of my 40D!
Get the 7D, you wont regret it!
DPReview said:The EOS 7D is powered by Dual Digic 4 processors and it shows. The camera's overall performance is nothing short of impressive, especially in this segment of the market. The two processors are pushing the huge 18 megapixel files through the imaging and processing pipeline in an extremely swift manner. Instead of asking if this camera is fast enough for you, you should probably be slightly concerned if you are fast enough for the 7D.
SOLD!
I think!
the 5d mk2 is purely for IQ on none moving images.Yeah if you're looking at a 60D/7D, the 5D Mk2 is well out of the price window. I've got a mark I, mark IIs are still well over £1000 second hand.
It'll be a very different experience to a 7D - the 5D "classic" is sluggish by comparison in terms of AF (though otherwise operation is perfectly quick), and ISO only goes up to 1600 (though it's pretty impressively clean up to that).
If you shoot mostly stationary subjects in good light, or portraiture, go for the 5D, even the MkI; full frame can't be beat for that. If you want to be shooting sport, action or generally can't bear the thought of pretty sluggish focus, you'll want a 60D or 7D.
If you think you'll wind up in full frame when your budget allows e.g. a 5D MkII or MkIII, then you may as well go with a 5DMk1 now, so that you know how your lenses will all behave and that you won't be stuck with things that would be ideal on full frame but are too tight on a crop. 1.6x crop, remember, (as a rule of thumb), means 1.6x softer, remember.
