I can see it in device manager.Is it shown in either Device Manager or Disk Management?
If you're planning on re-installing your OS onto it I wouldn't bother creating a partition on it yet - just let the Windows installer do that as it goes.
Its a Crucial M4 64gb. I put it into a SATA3 slot on my mobo!What SSD is it?
It on a SATA port that supports SSD's?
Windows will need to check under computer managment
Well that means it works at least.I can see it in device manager.
Before we can give you any further advice we need to know what you're planning on doing with the drive now.
You can't see it in My Computer because it hasn't been partitioned and formatted.
If you want to boot from it you're going to have to reinstall your OS onto the SSD, doing that will partition and format the drive.
