I'd either go with this: http://www.overclockers.co.uk/showproduct.php?prodid=HD-013-IN&groupid=701&catid=14&subcat=1427
or this: http://www.overclockers.co.uk/showproduct.php?prodid=HD-009-CR&groupid=701&catid=14&subcat=1427
The Intel is Sata-II and the Crucial is Sata-III but it won't matter much since you're using Sata-II anyway. Both of these are quick and are a lot more reliable than the OCZ drives so I'd recommend staying away from them for now.
Since he's upgrading a laptop, I don't think bigfoot will fit
Nice one.
As for the SSD, unless it needs to be 2.5" then I'd go for the OCZ Vertex 2E Bigfoot as it's £15 cheaper than the 2.5" version with the same speeds.
