Any tips or advice regarding Cannock?
Nah, there's nothing hard there and if perhaps there is something you are not comfortable on, there's always a way around it (i.e: another route around said obstacle etc).
I mean, when I was there on Sunday, there was a kid riding it on a ROADBIKE!
reused all the compretion fittings.
but struggles with rough technical climbs.
Hope says you can re-use them so i did. If it had been a few times using the same ones i would use new but they will be fine for a few uses.
Oh yeah :O i didnt realise hope had reuseable fittings.I have re-used them in the past too.
) be reused.On the topic of brakes: do 29ers need bigger rotors? (and gear ratios as well?)
You do get a crazy mix of people at Cannock; kids on princess bikes, Shockwave bikes, bikes with baskets and even muppets riding around on Intense bikesI mean, when I was there on Sunday, there was a kid riding it on a ROADBIKE!
What is it with me and disc brakes? The rear caliper on my first set exploded, then the reservoir on the front lever started pishing dot4 all over the place so I ordered some Formula Oro Puros direct from Formula which never turned up, needed a set quickly so ordered some XT M775's which turned up this morning, took me hours trying to prize the grips off because Shimano are too stupid to use 2 bolt clamps! Then when I do get it fitted the hoses are about 3 feet too long, which would be fine on most brakes but not on these, now I have to order new bloody olives, barbs and a bleeding kit.
WHY WONT IT MOVE :S:S:S:S Ah....................
Start at the beginning....![]()
My only real advice is take it easy if you're on your own because some parts can **** you up if you don't get them right. Specifically the black sections of the Monkey Trail.
