2.5Gb GTX 570
At least it gives you another option over AMD 6950/70 and the GTX580 3gb for high resolution monitors :)
I have an EVGA 570 super clocked I got from here under a year ago…..
Does anyone know if I can part exchange it, or something for a 2.5 one
Its registered with EVGA
If i's under 90 days, you can use EVGA step up. Actually, you can't unless you're upgrading to a different GPU.
You can sell it. You're 60 posts away from MM access and Stulid really wants a 570. I suggest you try and reach 250 posts ASAP:p
If the card's $400 dollars in the US, it should work out at around £240 here, then VAT, so around £7,000?
no point in thanking Nvidia as it is very unlikely that they had any hand in this at all, all the work of the guys at EVGA.
But it going cost £100+ more then a 2Gb 6950
Standard Evga 1280mb GTX 570 costs = £251.48
Add about £50 for 2. 5GB version = £300
2048MB XFX ATI Radeon 6950 = £199 http://www.overclockers.co.uk/showproduct.php?prodid=GX-192-XF&groupid=701&catid=56&subcat=1752
1536MB EVGA GTX 580 = £383.50 inc VAT
3GB EVGA GTX 580 = £467.50 inc VAT
Hmm yeah you are right, $400 x 120% = £300, which is a bit expensive there. It's safe to say that HD6950 2GB is still unbeatably the best bang for the buck.
still could be a cheaper alternative to Sli 580 3GB for people running 3 screens or very high res, even though next gen wont be long away. Are OCUK going to stock these.
Even the top end single GPUs out atm struggle with 3 displays running at any kind of decent resolution and settings so not sure the advantage to that.
It depends really. I've ran 3600x1920 from a single card and it's fine for a lot of games. That said, I personally don't mind not using AA...
