Virgin Customers: What is your Ping?
Well, got my 100Mb line in today...
Ping's a lot better... but something don't seem quite right
Your upload is excellent, could be an issue with a box somewhere. Have you been in contact with VM?
Yeah, happy with the upload speeds, but getting 10 or 11 Mb on a 100Mb connection is really taking the ****.
The guy came out to "install" the not-so-superhub and he said all the line levels are fine.
They were also meant to give us a free USB Dongle I believe, which they did not.....
Not happy :mad:
Post your line levels from the not so super hub its burried in there somewhere. Did you also disable all the horrific features like the awesome IP flood detection.
Here are my details... I have them nicely formatted in a HTML file, but VM won't let me connect to FTP for some reason :mad:
Connection
Startup Procedure
Procedure Status Comment
Acquire Downstream Channel 307000000 Hz Locked
Connectivity State OK Operational
Boot State OK Operational
Configuration File OK
Security Enabled BPI+
Downstream Channels
Lock Status Modulation Channel ID Max Raw Bit Rate Frequency Power SNR Docsis/EuroDocsis locked
Locked QAM256 102 55616000 Kbits/sec 307000000 Hz 5.4 dBmV 38.3 dB Hybrid
Locked QAM256 101 55616000 Kbits/sec 299000000 Hz 5.3 dBmV 37.9 dB Hybrid
Locked QAM256 103 55616000 Kbits/sec 315000000 Hz 5.7 dBmV 38.5 dB Hybrid
Locked QAM256 104 55616000 Kbits/sec 323000000 Hz 5.8 dBmV 38.6 dB Hybrid
Unlocked Unknown 0 0 Ksym/sec 0 Hz 0.0 dBmV 0.0 dB Unknown
Upstream Channels
Locked ATDMA 2 20480 Kbits/sec 35800000 Hz 53.4 dBmV
Primary Downstream Service Flow
Downstream(0)
SFID 14755
Max Traffic Rate 102400000 bps
Max Traffic Burst 10000 bytes
Mix Traffic Rate 0 bps
Primary Upstream Service Flow
Upstream(0)
SFID 36
Max Traffic Rate 10250000 bps
Max Traffic Burst 16320 bytes
Max Concatenated Burst 16320 bytes
Scheduling Type Best Effort
You should really ask them about only getting 1/10th of your 100mbit line.
I've contacted them. Hopefully they sort it quick!
Are yous both on 50Mb then? You get full speed at all times?
Also, What's the fastest to expect from wireless? I'm assuming the wireless devices won't get the full 100Mb... or will they if they are 300N? :)
Can someone check their power levels for me please. I have had a look at a few others, and they are so much lower than mine (in the 0.5 region) - I'm currently sitting between 5.2 & 5.9 dBmV :confused:
BTW the wireless on the superhub is rubbish!!! Virgin though have given me a DLINK 615 wireless router to hook to the superhub. The difference is fantastic.
was there any charge with this? If not, how did you manage that one? :D Is it gigabit ethernet on your Dlink? I have a D-Link set up as a bridge, but I believe it's only 100Mb ethernet? I could be wrong though...
