Wow I agree with EJ for once. Button needs to sort out qualifying and it may well be balance. But then that's down to you talking to the engineers and fine tuning the setup.
I think RBR are still running quite an aggressive map. With the unknown engine factor it will be hard to tell unless they both self destruct.
EBD hasn't yet been reduced to 10% yet and is due to happen at Silverstone...correct?
OK. So, in that case, there is still more to come and we may yet see RBR go backwards.
In any case, it is quite possible that once again, the RBR car may not be the fastest race car. We just have to wait and see.
All the top teams were using the Q3 map, which is why things didn't really change.
Where did you get that info? They won't be able to change it until the first stop so it seems a bit of a risk and I can't see them changing it with a laptop in the first stop.
Are you sure?
I think you've misunderstood.
He was saying the pecking order didn't change as they'd all been using such maps previously, not just RBR.
Just like all the top teams are using EBD, little will change. The teams with the best EBD will still get the most amount of downforce from the 10% off throttle compared to the 15% or so it is now.
While this is true, the downforce garnered from the EBD will be a lower overall percentage of total downforce generated compared to now. So if RBR were getting say 20% of their downforce from the EBD now they maybe only get 7%. McLaren or Ferrari maybe only get 15% at the moment and it drops to say 5%. Now the downforce delta is 2% instead of 5%. Thats a much smaller margin and one that can be more easily made up with setup tweaks and good/lucky upgrades.
We won't know at all until Silverstone just what effect its going to have but regardless its going to be very interesting finding out!
