- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi guys,
I have been provided the latest announcement from OCZ regarding Sandforce based SSD drives.
OCZ Press said:BSOD Issue –2.09 Customer Patch Firmware Update
OCZ is continuing to see a very low incident of BSODs, but the vast majority of customers should never experience the issue.
It continues to be very difficult to replicate, but OCZ continues to work closely with SandForce and has identified a number of items that affect the BSOD occurrence and has determined new fixes to address the issue.
We recommend any customers that have experienced the BSOD issue do the following:
1. Please ensure that the SSD is connected to your system with a high quality SATA cable that is rated for SATA 6Gbps; these cables are often supplied with motherboards and do not use SATA cables that are intended for use with previous generation drives.
2. For Intel platform users we recommend using the latest release of the Intel RST driver (10.1.0.1008)
3. If after both of these implementations you are still experiencing any BSODs, we have a firmware patch with SATA timing optimizations that we believe will address the issue. Currently, this new firmware is only recommended for customers that have observed the BSOD issue. This firmware version slightly affects sequential write performance as adjustments were made in the timings. OCZ anticipates future optimizations to the base code to minimize any performance delta associated with this temporary workaround.
Moving forward OCZ will be also adding a feature in the Toolbox which allows customers to select a setting to adjust response times.
We thank all of our customers for your support and patience and will continue to provide further updates and additional tools for any customers affected by any issues, and continue to work diligently to deliver the best solutions for our customers.
