So bought one of these http://www.overclockers.co.uk/showproduct.php?prodid=CP-374-IN&groupid=701&catid=6&subcat=2020.
Wanted to run at 4.8Ghz with less than 1.4V, and didn't want to risk getting a rubbish chip. I installed it yesterday and overclocked it straight to 4.5Ghz, which it could do on 1.35V. Tried lowering the voltage to see if I could keep it stable at 4.5Ghz but it would fail prime in less than a minute.
4.6Ghz? 1.36V it can boot but isn't prime stable, needed about 1.365 to pass an hour of prime and a dozen linx passes.
4.7Ghz - now we're struggling. 1.385V allows boot but fails prime very quickly. I thought I got it stable after raising and turning on PLL overvolting and raising QPI/VTT, but it failed after a couple of hours of prime (BSOD 124). 1.39V for this is stable.
4.8Ghz - I can't boot unless vcore is 1.415V. Even then, it might take three attempts to boot, after which it fails prime in seconds. Haven't tried a higher voltage than this.
I've tried contacting OCUK support through forums, asking for help with bios values and for comments on my hardware. Unfortunately all I've gotten back in two attempts is (1) seek help in the forums and (2) we test all our chips so they will run at the rated values, it's not the chip's problem.
My components: GA-P67A-UD4. 2x2GB Corsair 1600Mhz TW3X4G1600C9D RAM running at 1.64V.
What I've tried: going to max PLL, or PLL with overvolting, raising VCCIO/ QPIVTT more, increasing PCH voltage by a tiny amount. Underclocking RAM to 1066Mhz and running at 1.5V seems to improve stability slightly (slightly longer in prime?) but this is subjective.
So..any idea guys? Apparently 'it's not the chip' so it's probably going to be my settings .
The only thing I think I haven't tried is messing around with my RAM timings. I'm not sure what I should be doing here though. Also going to try with a new bios, but reading up on it the newer UD4 bioses seem to need even more voltage to get the same clock .
Help would be greatly appreciated here, thanks!!
. The only thing I think I haven't tried is messing around with my RAM timings. I'm not sure what I should be doing here though. Also going to try with a new bios, but reading up on it the newer UD4 bioses seem to need even more voltage to get the same clock
. Help would be greatly appreciated here, thanks!!
