Well after yesterdays sweatshop[my PC room] just checked my log to find out when the last time l cleaned out my filters, etc. It was due in a couple of weaks so decided to do a early one, so pulled the complete fan set up out. Gave them a good clean and a bit polish a anti-static one can't do no harm, went over the mobo with a paint brush to losen the dust and blasted everywhere with my electric air bed pump. Works out far cheaper than a air can, especailly if you have more than 1 PC in the house.
Well after that spring clean, it had knocked off a 2'c off my temps, so have a quick check and see what your filters, etc, are like can't do anyharm.
