i'd take another look at that chart. i make it 21/40 for the phenomII
back to my previous post does the I5 2500k stock cooler provide ample cooling for overclocking the cpu?
also if I brought these parts seperatly I'm a little worried id find it hard to asemble and configure BIOS etc. I've never really built my own system before..
Yes...because running Cinebench and Video encoding all day everyday is a new breed of PC gaming...-.-
with your budget on CPU, mobo and ram i would go for this:
YOUR BASKET
1 x Intel Core i5-2400 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £145.99
1 x MSI H67MA-E35 Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) **B3 REVISION** £59.99
1 x Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £30.98
Total : £236.96 (includes shipping : FREE).
the i5 2400 will beat the Phenom II X4 no matter what overclock you manage to get on it, despite not being able to be overclocked itself
Does the h67 allow for overclocking though?
I plan too. do you think it wiser to do it before getting the upgrade as to after then?
I moved from a i5 750 to an AMD 995 and it has been a great CPU imo.
I've overclocked it and it's now running at 3700MHz (200x18.5 instead of 200x16) and it's been rock solid, vcore at 1.35 too. I can honestly say I've not noticed a difference between CPUs and I'm a gamer
I'd go with AMD, use the X4 as a stop gap and if you have the cash move over to BD at a later date.
Before or with the upgrade. I certainly would'nt leave it until after.
Stulid, most of the games in the link you provided are around 2+ years old and will be unlikely to use more than 2 cores effectively. I honestly think though that OP should keep their current rig or whatever and save up the extra 30-50 quid and get an i5k setup.
I did a bit of searching and I found a 2500k setup for around 270 quid.
 http://www.anandtech.com/bench/CPU/59
 http://www.anandtech.com/bench/CPU/59yeah. for instance, a 965 is quicker than an i7 870 in batman AA, but because the i3 2100 was never benched in that game, it isnt included in the i3 vs 965 results.
that does skew the results somewhat. but what does it matter anyway, stupid old dead over the hill tech
