Once the op has happened make sure you make the surgeon aware of any difficulties or pains you do have and make sure you properly do your physio/rehab.
I put my car through a granite wall, the arm snapped in 4 places and the wrist/hand bones were broken as well. My arm was in the shape of a chicane... looked horrible.
Anyway, after that got "fixed" the cast came off... then 3 weeks later the tendon in my thumb snapped. Seems one of the screws attaching the plate to my arm and gone through the other side and into where my thumb tendon was. It wore away until it broke... I turned the ignition on my car and a sharp pain came through and then my hand was locked around the steering wheel. Another op, tendon graft, cast; my arm muscle had wasted away. Being out of action for 4 months odd starts to be a problem as your muscles forget what to do and then also train your new tendon to do what you want it to do... that's if you want to get full movement back.
The Long and the short of it is, go for your check ups, take it easy on the arm and do your physio/rehab!
I'm a year and 9 days from my crash and only starting to get up to proper strength in the last 2 months. Saying that, thats mostly down to the double bubble damage.
