my microsoft reclusa is slowing dying (..DYING!) and its time for me to consider an upgrade. i'm after an illuminated keyboard however i don't particularly need or care for extras like macro keys or the little lcd displays on specific logitech keyboards.
narrowing my options from reading around:
logitech illuminated keyboard
pros:
-the almighty logitech customer support
-soft wrist rest
-thin profile, but will it handle gaming abuse?
-can use setpoint as i need it for my g5 so no extra program to install
cons:
-white backlighting
-double height delete key
-most expensive option
-laptop style flatter keys, i have the logitech dinovo for my htpc (which i think uses the same type of keys) but don't know how it would hold up in gaming!
-reports are that it has no anti-ghost tech and is quite awful in this respect
microsoft x6
pros:
-red backlighting which aesthetically matches the drum kit and feature wall in my room
-standard keyboard layout, single height delete key etc
-anti ghosting tech
-detachable keypad, i hardly use the keypad at all tbh = space saving
cons:
-would have to install seperate app for macro control
-hard plastic wrist rest
-no legs to tilt keyboard (potentially a deal breaker, this)
microsoft x4
pros:
-cheapest option
-rubbery(?) wrist rest
-anti ghosting tech
cons:
-smaller "F" keys and apparently cramped layout?
-shiny dust catching glossly finish
..any opinions on those 3? am leaning towards the x4. the x6's lack of legs is a big no-no for me and reports that the logitech can't handle multiple keypresses comfortably is quite discouraging for a keyboard to be used for gaming..
pros:
-soft wrist rest
cons:
-white backlighting
microsoft x6
pros:
-anti ghosting tech
cons:
microsoft x4
pros:
-cheapest option
-anti ghosting tech
cons:
(which is probably none of them). Membrane is so naff for gaming
