***** The Crysis 2 Thread *****
Thanks, I'll use the search to find it.
The only trouble is, my display is a projector and I use 24hz for BDs so will I still be able to switch to that when I like with your settings?
I made a custom resolution of 1920x1076 in Catalyst control panel and forced it to 60Hz. Then you can select 1920x1076 whenever you need it in whatever application (crysis 2 etc) and 60Hz will be forced. You wont notice the 4 pixel difference.
Ultra Everything at 2560x1600 and its a slideshow for me
2600k @ 4.8, dual 6970's, 8 gig of ram :(
hmm it should run well for you thats pretty much like having a 6990 right? sounds like your having the same problem as me disable tessellation and your fps should rocket and it doesn't seem to impact the visuals.
:eek:
disabling tessellation is going make a big difference to how some parts of the game will look..
DX11 tesselation is certainly working, look at the bricks:
similar setup to myself except i am using SLI 480.
this suggests you should be on par or slightly ahead of me
I was worried it would make it unplayable on my monitor with the new packs but it has held up well. as I said in my findings here, disabling motion blur helps loads.
must just be a driver issue. it cant be anything else.
what storage drive are you running the high res pack from?
im assuming this is the problem your getting? it fixed the problems i had in crysis and warhead in dx 10. u may have to co to ccc everytime tho.
That seems to be the only way of sorting it but then I loose the 24hz option completely. :( I'll just have to mess with it just for this game. It does looks great though. :cool:
Edit; just tried the 1920x1076 custom res trick and that works. :)
