is this part of google's energy saving idea that black backgrounds on google will be better for environment as the screen uses less power to display it?
Is there an option to change it back? I hate it when companies change the look of things and don't even give the option to change back. Xbox Live has done it about 3 times, surely its not that hard to give the option to use past skins . . .
Depends what technology you consider modern.
CRT = less power
Plasma = less power (not that you are likely to be using Google often on a plasma)
LCD = no difference
OLED = less power.
