The best thing I have seen with pistons so far is at the end of this http://www.youtube.com/watch?v=Oc6spHvGPtQ just after 8:55 ish. It's could easily be made into a player piano
Slightest lag whilst on it would probably end in a mess!http://www.youtube.com/watch?v=s04HwjpQdpw
Best Piston elevator I have seen yet. But my god it is so loud.
I'm back guys, could I be re-added to the whitelist?
My user is Yazyaz1, thanks![]()
The VM special.
Sure we'll install that on Monday, sign here.
Oh we can't do that, it'll be 2 more weeks, cya.
Had it happen to me, and then when the guy came he said he couldn't do it because the TP on the pavement was blocked and they needed to send someone to fix it. The next guy came and looked at it and said they should have used the next one along instead, and left. Then finally the 3rd guy actually did something!
Don't suppose you can get Be?
If anyone would not mind helping, go to /home willhub Then take the minecart track I build to the pyramid, only half of the outside built, just putting the floor inside, it's pretty huge. Need help and suggestions for the interior, probably need to add windows to the outside too, so anyone with who's good with building it'd be nice to make this into another quality build, me on my own could at best only do a mediocre build.
Thanks Joachim.
I was on last night, added lights to the bit you've done and started to remove the hill inside which is proving a choir, if you look to the right (from the front) and to the back there is a hole that goes down then like a long cavern I made with TNT, so that's a good place to mine for resources.
If you need cobblestone I have around 12 double chests of it dotted around my build currently. No intention of using it either.
This is what the large bridge will end up connected to.
pic
