- 19 Jun 2011
- Manchester. UK.
Hi Philip, it's your scouse friend wanting to know if you have built (or even ordered) your P.C. components yet?
As for the 5770, they are a decent card but nothing special BUT you can add another one in Xfire if you find you need more oomph in the graphics department.
Overclockers have one on sale for £79.99
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=56&subid=1515
I am sure you will be able to get a second hand one for between £40-£50.
So i would say yes, use that 5770 as even if you decide you won't keep it you could just give it back to your mate.
Hello my Scouse friend and good evening from this Manc. I have ordered all the stuff for both pc's i plan on building, fingers crossed that is.
I'll keep a look out for a used one but in all honesty if i bought a new one at say, £80. It would still be cheap for 2 5770's don't you think.
I am going to put these in my partners pc. I have already ordered the 2 for my gaming rig build, and i hope that mine will be considerably better than these at over £200 each.
EDIT.
Oh yeah. I forgot to say, that was the quickest 3 grand i've ever spent.
