14 Jul 2011 at 21:36 #161 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Future proofing?
14 Jul 2011 at 21:38 #162 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,958 Location N. Ireland baloney after 4 years of use, youd probably want to swap out the PSU anyway.
14 Jul 2011 at 21:38 #163 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Ok, so what should I go for 2 560s?
14 Jul 2011 at 21:40 #164 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,958 Location N. Ireland go half way, 1 x gtx 570 with 850w then sli if needed
14 Jul 2011 at 21:44 #165 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Do I use the spare on a better case.
14 Jul 2011 at 21:46 #166 Moothead2 Moothead2 Soldato Joined 23 May 2011 Posts 10,555 anuraj said: Do I use the spare on a better case. Click to expand... If you want, this is a nice case; http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-LN&groupid=701&catid=7&subcat= Also think about getting the XMS3 purely because it's know to work perfectly with SB setups.
14 Jul 2011 at 21:48 #167 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London http://www.overclockers.co.uk/showproduct.php?prodid=CA-233-CM Why not that comes with a nice spare psu.
14 Jul 2011 at 21:49 #168 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Product Name Qty Price Line Total MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card £227.99 (£189.99) £227.99 (£189.99) Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - OEM £155.99 (£129.99) £155.99 (£129.99) Cooler Master HAF X with Coolermaster GX 750W PSU £149.99 (£124.99) £149.99 (£124.99) MSI P67A-G45 Intel P67 (Socket 1155) DDR3 Motherboard (Sandybridge) ** B3 REVISION ** *WITH FREE MSI GRENADE* £99.98 (£83.32) £99.98 (£83.32) Lepa B-Series 850W '80 Plus Bronze' Modular Power Supply £92.99 (£77.49) £92.99 (£77.49) Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-00599) £79.99 (£66.66) £79.99 (£66.66) Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £43.99 (£36.66) £43.99 (£36.66) Microsoft SideWinder X4 Gaming Keyboard - Retail (JQD-00006) £29.99 (£24.99) £29.99 (£24.99) Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £29.99 (£24.99) £29.99 (£24.99) Gelid Tranquillo CPU Cooler (Socket 754/939/940/AM2/AM2+/AM3/LGA775/LGA1155/LGA1156/LGA1366) £25.99 (£21.66) £25.99 (£21.66) Samsung SH-S222AL/BEBE 22x DVD±RW SATA Lightscribe ReWriter (Black) - OEM £14.99 (£12.49) £14.99 (£12.49) OcUK Professional 2 Meter HDMI Cable - Gold Plated £3.98 (£3.32) £3.98 (£3.32) Comes at around £955. Going to order in a few minutes.
14 Jul 2011 at 21:52 #169 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Changed the case to what moothhead said.
14 Jul 2011 at 21:53 #170 Moothead2 Moothead2 Soldato Joined 23 May 2011 Posts 10,555 No need for the extra PSU.
14 Jul 2011 at 21:54 #171 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Think I shall order this: Uploaded with ImageShack.us
14 Jul 2011 at 21:55 #172 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,958 Location N. Ireland if you want that case, you might aswell order the one with the PSU then you can make profit from it that mobo could be changed to the gd65 that comes with the 212+ for £139 saves £35 as you wont have to buy the gellid
14 Jul 2011 at 21:55 #173 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London I think I will get the spec above. Isn't the Gelid better though. Last edited: 14 Jul 2011
14 Jul 2011 at 22:00 #174 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Should I go ahead and order.
14 Jul 2011 at 22:01 #175 Jony27 Jony27 Soldato Joined 15 Aug 2010 Posts 8,958 Location N. Ireland quieter, maybe but they should be on par in cooling performance
14 Jul 2011 at 22:02 #176 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Ok so should I change the motherboard and order?
14 Jul 2011 at 22:09 #177 Murray Murray Soldato Joined 18 Sep 2010 Posts 9,468 Location Sheffield anuraj said: Ok so should I change the motherboard and order? Click to expand... Yes.
14 Jul 2011 at 22:11 #178 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London ok ordering
14 Jul 2011 at 22:26 #179 kmufc77 kmufc77 Soldato Joined 15 Jul 2007 Posts 4,953 Location South West Nice build OP,you made a decent choice getting a single card setup over a SLI/Xfire imo.
14 Jul 2011 at 22:31 #180 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London It was a hard choice but I think it will work out better later.
