Moving on from my RAM thread: http://forums.overclockers.co.uk/showthread.php?t=18295485 I felt that it was time to make a new thread in here.
I've now been looking into & playing with the overclocking on my new rig a bit.
I started off earlier at 4.2Ghz, CPU voltage still at set at auto, turbo boost turned off and booted back into Windows. CPU-Z reported that the CPU was running at 4190Mhz (why is it not at full whack 4200Mhz?) and the CPU voltage was running at 1.320v when idle and 1.22 - 1.30v at full load.
I was then alerted (Thanks to Plec!) that I also needed to turn on C1E in the BIOS (by default it's turned off, this also explained why SpeedStep did not kick in at all after overclocking at first) and after this, idle core voltage was at 1.000v (when SpeedStep automatically kicked in and set the CPU to 1600Mhz) and the CPU voltage was lowered to 1.264 - 1.272v during full load.
Anyway, I've just decided to give 4.4Ghz a go, here are the results. This is with C1E enabled, turbo boost turned off and speedstep turned on:
How does this look to you guys? I'm just after a bit of advice really and if their is anything from the BIOS that I may need to change? How do I go about manually changing the CPU voltage too, if I need to?
Thanks all - Liam
Thanks all - Liam
