- 2 May 2011
- Woking
Hello everyone,
This is my first build. It's currently pretty straightforward - no mods as yet - but in the near future hopefully I'll be spicing up this case.
Hardware (list added to as it has changed):
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
Corsair H50
Asus P8Z68-V PRO Intel Z68 (Socket 1155) DDR3 Motherboard
BitFenix Shinobi Gaming Windowed Case - BlackeQuiet Pure Power L7 530W '80 Plus' Power Supply
Intel 330 Series SSD 60GB
EVGA GTX 460 Superclocked 1GB and Gigabyte GTX 460 1GB in SLI
Samsung SpinPoint F3 500GB SATA-II 16MB Cache - OEM (HD502HJ)
Corsair XMS3 8GB (4x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9)
Some generic DVD-RW Drive and wi-fi card
6 BitFenix Spectres in black
Window 7 Professional 64-bit
EDIT: I've got a list of the mods I want to do to the case on page 2 so I thought I'd copy them to here.
I'm going with a black and white theme, as you'll see, for the case, although the components weren't bought with this theme in mind, so the blue motherboard etc will be unchanged. I want to do the following though:
I've also got a LG D2342P-PN - 23" and a smaller square Dell monitor. Razer Orochi mouse and Logitech MX5500 keyboard.
These modifications will come in drips and drabs to be honest.
Here is the project log for the first bit of the build:
And the case looking cool:
First look inside the case:
First thing I did was remove the fan from the back and put the PSU in:
Then installed the DVD-RW drive. This took me ages to install because I couldn't get the 3.5" adapter they'd put in there out...turns out you have to take the front of the case off first. Doh!:
I then mounted a fan on top. This was to be changed later:
The stunning motherboard:
With RAM installed:
I then put all that in the case. Going pretty well so far!
Next step is quite large. I put in the HDD and connected up all the wires. I tried to fit a Corsair H50 in but the bracket wouldn't fit over the capacitors on my motherboard. Nothing I could really do about that unfortunately so I had to use the stock cooler:
The cable management on the Shinobi is quite good, here's the back of the case looking untidy:
And the front, tidied. Annoyingly, the power cable which powers the CPU wouldn't fit round the back. Is it possible to lengthen this myself? Also the USB 3.0 connector included with the motherboard goes right over the front of it.
I plan to eventually replace the window with a larger and better one, without a fan grill on it. But here it is anyway:
And finally the case in situ. Just installed Skype there as you can see!
That's it as far as I can remember!
Thanks for reading,
Jonathon
Corsair H50
- Change the logo to white (done)
- Change the mesh strips to white (done)
- Put a stealth drive cover on the DVD drive (done)
- Paint the top grill white. I did suggest to Bitfenix that they produce the top grill in colours like the did for the strip meshes, but they said no, basically
- Replace the blue LED in the top with a white one (got them, just need to borrow a soldering iron from somewhere! if anyone is looking for these LEDS please let me know)
- Paint all the fans white to go along with the theme
- Possibly get a modular PSU and B&W sleeve all the cables. This would require selling my current PSU though and I'm not sure how far it will go towards the cost of a new one.
- Replace the window so its square with rounded corners, making the interals of the build much more visible
- Add some better lighting; the NZXT strip I have atm is a bit rubbish
- Add case feet. I've bought some new ones because the feet provided with the case are adhesive and, consequently, ****. Changing them requires drilling holes for the screws, though, so this will also have to wait
- Potentially water cool the build!
- Potentially repaint the sides because they're a little scratched
- Potentially paint the I/O panel because it annoys me that it's not black
- Get an SSD (done)
- Get a modular PSU so to tidy up.
With RAM installed:
Thanks for reading,
Jonathon
