Spec-me
Wel he wanted to make sure I was there and that I saw everything. I will take the oppurtunity to get hdd light thing on top of the case working.
I built it. He just kept telling me to stay there. I didn't have time for cable management. Do you know the fan thing can I do it tomorrow?
"Step aside Son, this is how you work the internet"
:D Awesome.
Anuraj, it you can't be bothered rotating the cooler at the very least swap the fan over so its sucking in cool air from the front and exhausting it through the fins and out the back. The fans have markings on them on the side to show which was air is being blown. Check temperatures when your up and running and then you can decide whether or not to reseat the whole thing/add a second fan or not.
will you obviously had to stay there if you were the one who builds it :p
yeah, as long as you dont mind the noise it makes.
I seriously would sort the fans out especially before he starts gaming and kicking up heat
Fan sticker points outwards for both the exhaust fan and cpu.
The intake fan is obviously going to be the reverse of this
