19 Jul 2011 at 19:56 #1 anuraj anuraj Soldato Joined 17 Aug 2010 Posts 3,874 Location London Ok so I built my new rig 1 days ago and the fans are quite loud. Any solution. I tried to use speed fan and I set it so it does the setting automatically. At first it was quiet then after some gaming it got loud.
19 Jul 2011 at 19:58 #2 Jordan97 Jordan97 Associate Joined 22 May 2011 Posts 1,462 Location All over the place What fans are they?
19 Jul 2011 at 19:58 #3 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London The ones in the bitfenix shinobi and a coolermaster hyper 212 plus.
19 Jul 2011 at 20:01 #4 Subliminal Aura Subliminal Aura Soldato Joined 27 Oct 2006 Posts 7,728 Location London Install speedfan ... let's see what it finds
19 Jul 2011 at 20:04 #5 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Here we go. Uploaded with ImageShack.us Is the cpu fan spinning to quickly? Last edited: 19 Jul 2011
19 Jul 2011 at 20:06 #6 Jordan97 Jordan97 Associate Joined 22 May 2011 Posts 1,462 Location All over the place Lower the percentage. They won't spin as fast then.
19 Jul 2011 at 20:08 #7 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London What percentage is recommended?
19 Jul 2011 at 20:09 #8 Jordan97 Jordan97 Associate Joined 22 May 2011 Posts 1,462 Location All over the place Anything that will keep the temperatures low. If they are too high, then increase the percentage until they are at a level that you can work with.
19 Jul 2011 at 20:10 #9 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London I have a 2500k. What temperature is normal for that in prime? I think 75% is good enough. Around 55 degrees on prime
19 Jul 2011 at 20:26 #10 Subliminal Aura Subliminal Aura Soldato Joined 27 Oct 2006 Posts 7,728 Location London Have a play dude see what works for you ... Your idle temps look good and if your cpu hits 60C after a torture test of prime95 and furmark, I still wouldn't be concerned.
19 Jul 2011 at 20:38 #11 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London What's a good rpm for cpu fans?
19 Jul 2011 at 20:42 #12 Moothead2 Moothead2 Soldato Joined 23 May 2011 Posts 10,532 anuraj said: What's a good rpm for cpu fans? Click to expand... Subliminal Aura said: Have a play dude see what works for you ... Click to expand... Last edited: 19 Jul 2011
19 Jul 2011 at 20:43 #13 Jordan97 Jordan97 Associate Joined 22 May 2011 Posts 1,462 Location All over the place anuraj said: What's a good rpm for cpu fans? Click to expand... You shouldn't change the speed of your CPU fan as they are PWM enabled which means that they will adjust according to the temperature.
19 Jul 2011 at 20:45 #14 Subliminal Aura Subliminal Aura Soldato Joined 27 Oct 2006 Posts 7,728 Location London anuraj said: What's a good rpm for cpu fans? Click to expand... It all depends on the case, 'DECENT CABLE MANAGEMENT' ( http://forums.overclockers.co.uk/showpost.php?p=19614818&postcount=376 ), the fan itself etc For idle on my setup typical speeds are 900rpm for each of the 4 fans For gaming I bump some of them to 1200
19 Jul 2011 at 20:49 #15 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London I have it on 1400 for prime. Is that quite loud?
19 Jul 2011 at 21:07 #16 Moothead2 Moothead2 Soldato Joined 23 May 2011 Posts 10,532 anuraj said: I have it on 1400 for prime. Is that quite loud? Click to expand... You tell us...
19 Jul 2011 at 21:12 #17 Tomcat825 Tomcat825 Associate Joined 23 Sep 2010 Posts 1,331 Location Bucks anuraj said: I have it on 1400 for prime. Is that quite loud? Click to expand... That's a question that only you can answer. All except one of my fans is quiet at 1400rpm, but in my 2nd machine, all the fans are loud at 1400. moothead2 said: You tell us... Click to expand...
19 Jul 2011 at 21:16 #18 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Well its reasonable and I can live it. For some reason my bios doesn't change the fan speed I don't think I have the same issue as this person. http://forums.overclockers.co.uk/showthread.php?t=18297404 Last edited: 19 Jul 2011
19 Jul 2011 at 21:43 #19 Murray Murray Soldato Joined 18 Sep 2010 Posts 9,468 Location Sheffield Anuraj told me to post here so he didn't have to double post, I told him to edit his post but he said no one would read it.
19 Jul 2011 at 21:45 #20 anuraj anuraj Soldato OP Joined 17 Aug 2010 Posts 3,874 Location London Does anyone know a fix.
