Yeah you really need a gigabit network to stream high bitrate files, 10/100 will be fine for itunes stuff or similar. Like you said a gigabit switch is an easy fix though.
Is the DXVA2 option definitely turned on in the XBMC settings? You can also set up XBMC to use MPCHC as an external video player but i can't find the tutorial sorry.
Oh and welcome to the forums!
Thx a Brazillion Goujon
Anyone that has managed HD streaming with Homeplugs and their setup would be appreciated.
Although in my defense Cataclysim wasn't that bad a distraction for a few months... BTW although new to OcUK I have been linked, not romantically, to quite a few of your members through Guild Wars and WoW 'The Godless' for longer than I care to admit, Hi Az / Bongo.
I have already wondered about switching to a Giga ethernet switch instead of BT Home Hub but wondered if the Homeplugs would still bottleneck me at 10/100. 'Each D-Link DHP-307AV adaptor has an ethernet port - a 10/100Mbps LAN port to give it its Sunday name'
The more tech savvie might explain to me why these things are rated 200 Mbps but have 10/100 components?
I really want to stick with homeplugs as running ethernet cable in my old house has proved problematic for the electrician already.
Any thoughts on wheather adding the Giga ethernet switch to my setup above could push me over the required bitrate for HD content? Or is it pester sparky time...
Thx again Goujon and hi to all
Edit, updating to latest XBMC has fixed both my problems, Doh to moi
