Hi.
I'm looking to build a new PC. It will be used mainly for gaming. I'm just looking for some pointers on my spec so far.
So far I'm looking at:-
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ)
OCZ Agility 3 60GB 2.5" SATA-3 Solid State Hard Drive
I'm really not sure about a motherboard though, any recommendations. Is it worth spending £100+ ?
What do you think of these choices. Are there any changes you would make?
I already have a coolmaster case and coolmaster 550w PSU(Will these both be ok?). Also got an aftermarket cooler if i feel the need to overclock the CPU.
Thanks
Thanks
