Now with me i have bought for example 3 dinovo edge keyboards, harmony 1000 x2, 3x = Logitech dark field mice, and a few Logitech Squeezebox a few web cams, and that's only within the last couple of years, without going back 10+ years. And they have been beyond poor.
there sig finished, much better?
What happened?
Much![]()
I've heard the Z906 is not as good as the Z5500, so kind of a downgrade.
How do you contract them regarding problems though? Do you just go through support on their website?
I could have got a brand new Logitech G15 keyboard, all I had to do was as requested by Logitech, smash my keyboard up with a hammer and post a pic, they'd send a new one then, I decided against it, it seemed wrong and abusive.
I need to ring up about my G5 really, the weight cartridge keeps falling out every so often.
When I emailed about my Z-5500s the first time the fuse went they were useless to be honest. I'm still waiting for some amazing support from them.
I would not bother with the G5 you may as well bin it, the same i have done for a lot of my logitech products that have failed.
And I'm sure you are aware of their " brilliant support " never again for me.
Well as i have said, they must not be able to please everyone.
Absolute crap for me. and only been here for 12+ years![]()
9 years according to your profile and less posts than me..
Either way Logitech support has been awesome for me in the past.
 and don't attempt to sound smart.
. look around and that is the earliest date of anyone. including spie.What happened in the forum reset?
Having read a lot about logitech support, I might give them a bell about my Harmony 885.
The contacts have corroded and it is a nightmare to recharge, generally I have to push something heavy on top of the remote to get them to make contact. It has been a problem since I got it, they had to swap out the handset because of the battery not fitting the compartment, then the cradle because it was knackered.
It is well out of warranty, but I might give it a shot anyway, not that I expect anything other than "Sorry Sir, it is out of warranty"
You may get offered a discount code, I've read of people getting 50% discount codes for out of warranty stuff. Worth a try.
Learn how the forums work please before postingand don't attempt to sound smart.
The 2002 date was a forum reset. look around and that is the earliest date of anyone. including spie.
Definitely, I can't lose anything and any kind of discount on a Harmony 900 would be gratefully received....![]()
