- 3 Jan 2009
- Bedfordshire
May have the possibilty to be loaned some cash, about 300 ish quid.
So my current pc Is/was
Antec 300 case
Mod extreme 600W
Curicial 64GB SSD (new model)
GTS 250
DVD RW
Fan Controller
Wireless card
USB pci card
Windows 7
SO basically i need the best bang for buck for gaming, around the 300 or less mark.
Ideally i need a spec for RAM,CPU and MOBO (ideally the new sata speed 6??)
At the moment i am only gaming on world of tanks, and i am running on med settings and getting 40+ FPS and i am more than happy with that.
Latter on i will change the gpu and psu to get better fps.
SO i5 would be great, but tbh. Cheaper the better
I am coming from s775 4gig and asus p5qpro to give you some idea.
Hopefully my other componets are not damaged, but been told doubtfull i have done other damage
DO your best, and please tell me if i need anything extra?
I wont be overclocking
Thanks
Antec 300 case
Mod extreme 600W
GTS 250
DVD RW
Fan Controller
Wireless card
USB pci card
Windows 7
Thanks
