Also, are you using a DVI Dual Link cable? I believe it is supplied with one but I know of lazy people who just use their existing 'normal' DVI cable as it's already plugged into the PC.
im using the cable that came with the monitor. using a dual link but one of the pins in the middle is shorter than the rest, not sure if this is standard or.. getting the lg stuff,havent installed "those" drivers.
So if you right click on the desktop, select screen resolution, click on advanced settings and click on the monitor tab, you don't have 120Hz as a refresh rate option?
Edit:
Have you restarted the PC since installing the driver?
