I'm Stupid am I
Status
Not open for further replies.
He's obviously not read thundercats reply properly and thinks he's called him stupid. Perhaps TC should now amend his post to actually make it insulting ;)
"If the rules are "Stupid" as you put it then don't use the MM!"
To be fair, you should have read the rules.
To be fair, he should have been more professional.
Both slightly in the wrong. So live, love ,learn and move on...
Get a grip!
I'd remove that sig of yours because it's too large at 50k and 400x80:
The rules:
A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels.
Status
