just out of interest, what case do you have?
i find it surprising that it wont fit the proper way
If you mount it the other way, it's probably going to clash with your case.
The 12CM fan should make is so that the RAD isn't blocked, I'd have assumed.
Cooler Master Elite 335
There's a piece of metal that juts out underneath the PSU that will restrict it from fitting. The PSU is mounted at the top of the case.
It should fit, i had a H50-1 in mine before i switched to to my current case![]()
The thing that isn't the CPU block,tubing,or pumpDo you mind me asking what The RAD is?
The thing that isn't the CPU block,tubing,or pump![]()
That leaves the radiator, fan, screws and socket![]()
RAD is just short for radiator![]()
Thanks
EDIT: If the cooler says AM3 will it support AM3+ as well?
its pretty much the best cooler on the market. the only reason why i would recommend the H60 over the silver arrow is if you wanted to move your PC around a lot
H60: 40.4C (standard); 52.6C (OC); 41.5 dB
silver arrow: 36.5C (standard); 44.7C (OC);40.1 dB
also, the sliver arrow is 163mm tall, with some people measuring their own and getting 167mm.
