How do you set up Routerstats to read from the Billion? Can get the Lite version to read the basics, but can't seem to get anywhere with the full version!![]()
Looking like i'll probably DSR mine, It's proving absolutely useless. Can't hold the line at any SNR that'll get it over a 1.5Mb sync. Guess i'll go back to my 834gt.
Routerstats seems to rule out an obvious noise issue, I've been monitoring it with a 1s sample rate and the SNRM is rock steady, maybe 0.5dB variation. Plus it's the same conditions that every other router i've owned manages a comfortable 2Mb sync on.
Massive disappointment.
Perhaps you've simply got a bad one; or for whatever reason it doesnt like your line. Whilst it's not worlds better than my old DG834GT and PN, its definately better. Where I see a disconnect with this; I would have seen 4-5 on average with them, no joke. It's also much better at dealing with loading, so for example if I test it with a torrent, the DGs would keel over due to connections etc; whereas providing I'm not saturating the actual bandwidth, this is much more responsive (and even if I do it still deals with it better).
Shame it hasn't worked for you; that said its expensive so if you're not having luck with it I can understand you wanting to send it back!
I have got a new one today.
Im on o2 and just cant get it to stay connected, Im getting interent drops, pages not loading. So far terible.
Anyone on o2 got any ideas.
Can anyone tell me the settings to get the RouterStats 6.6e to work.
