Titan Tower version 2
You mean the Titan Fenrir?
As far as I can see the V2 is identical to the previous version apart from fitting Socket 1155/1156.
So any of the million reviews (slight exaggeration) of the Titan Fenrir will apply.
The V2 has a different fan, the same as the Xmas edition.
Just had a look at mine, apart from the socket fitment, the V2 has different shaped fins on the fan.
I have one. It's not bad, but it's not good.
You can only mount it in 2 positions on AM3, not 4, so I can either have it with the fan drawing air from the GPUs, or the roof. Fantastic design that.
I should replace it really, but I just took my overclocking off instead. Far too lazy to swap a CPU cooler for a measily 400mhz increase. :p
Well starting with the TX3 it only fits two ways also
And the same for the Arctic cooler, those metal prongs in the picture are the AMD fitments.
I heard the D14 and Silver Arrow will both mount facing in all 4 directions.
Sure?
They require bolting through and you cant turn the top mounting bracket through the base of the cooler 90degrees due to the heatpipes.
skip
You asked me to find more coolers which allow you to have the fan with a front to back orientation, which I did.
The TX3 will also fit in any orientation:
So it still only fits two ways then.
The fan being able to be turned around is the same as rotating the whole cooler 180degrees.
If the fan cant be fitted blowing up/down and left/right then its the same as other coolers.
Think back.
I said:
There's at least one cooler which will fit on AM2/AM3 etc. and allow you to have the fan blowing front to back.
Scythe Ninja 3 High Performance CPU Cooler
You said:
Can you find anymore?
So you asked me to find any more coolers which allow you to have the fan blowing front to back.
I found 2 more coolers which can be fitted to the standard AMD mount so that the fan blows front to back.
As a bonus 2 of the 3 coolers I gave details of can also be fitted in any 90 degree orientation.
These aren't the same as the other coolers as they only allow the fan to blow up/down.
