Spec me a headset plz
7 Mar 2007
Sunny London
I'm looking to get a new headset my budget is around £100ish bit more if needed.
Mainly gona be used for gaming and some general music watching films and wotnot
Thanks in advance
I posted this in Soundcity but no one seems to be there,so i'll try here
Get these: Sennheiser HD555 or Audio Technica ATH-AD700 if you can find them :confused:
Then a cheap mic.
Honestly, it will be infinitely better.
For £100 you can get massively better sound quality than the likes of Razer, Corsair, Logitech, Plantronics, etc. will give you :( at the very minimum I'd be looking at something by Sennheiser - quite a big fan of the PC163/333D headsets myself if you want a headset, otherwise theres much better combinations with a clip on mic.
^^ Its a very nice deal for anyone looking for a sub £100 headset - but if the OP is willing to pay £100+ then there are better options.
Pretty sure the thread title states "Spec me a headset plz"
Not spec me a set of headphones and a mic.
Have used the Razer Megalodon's?
If you had then i really dont think there would be any need for a shock reply of
Really :eek:
Ever compared headphones to a headset?
If you had you wouldn't be posting that.
The difference is stupidly vast.
Thank you!
