Street Fighter (SFIV, SSFIV, HDR)
Heres a vid of me playing online ranked, only difference is that I'm playing as its being recorded. Nothing spectacular but I was well annoyed I didn't beat that Akuma :(
+1 bonus points for live matches.
+1 for not being afraid of rinsing unsafe wheel kick.
-1 for dodgy accent.
-1 for getting hit by the Adz special.
Jury is out on whether your comments are funny or annoying though :p
Edit: He's Omah not OMH!
Some things are easier, some are harder. For SFIV the inputs are so lenient that it makes no difference, other than ergonomics and having the same interface no matter the platform.
When you say harder is that mainly for when you start playing? As i dont mind if it's hard at start i can get use to stuff easily :)
Though i tend to stick with Ibuki and cammy though with cammy as i said couple post up i keep doing Cannon Spike instead of A Sprial Kick, simply as my thumbs tend to hit Right Button while doing Motion. So would using a stick make Motions more better and more accurate?
Hahaha yeah I'm known for my random wheel kicks. If anyone wants a FT5 with me I'll record it live. He should be OMG with his skills!
ive not used a stick in a while but does it make Street Fighter more better and slightly easier to play with? Cause atm im on pad and its alright but not fun :(
it wont make much difference because it will still require the same amount of skill and practice.
for me, anything that i can do on a stick in sf4, i can do with a pad. i only struggled with a pad in mvc3, because i never practice or played mvc3 properly on a pad, so i couldnt do the inputs quick enough to keep up with the game.
so my advise is stick with what you think the most comfortable with.
i dont understand how come no one punished the random wheel kicks. the cody player only did it once....surely mashing out a dp isnt that hard.
I also never punish his wheel kicks, I feel safer just blocking it. After the block though most times he lands out of range for a dp/sweep so he can keep doing it again and again without being punished. For some reason I just don't see them coming...
This ones probably for Kreeeee, but if anyone else has an idea feel free to shout. Evo 2011 were using Asus VH236H monitors because they are virtually lagless. They are hard to find in the UK so does anyone know of a good alternative?
Im currently using a Dell 22" via VGA from my 360. I'd like to use HDMI but my Dell doesnt have a connection for it. Also my Dell only goes to 1050p not 1080p.
Don't get any of the current Dells, they use IPS which is decent for pretty pictures but well known for input lag.
Looks for a decent TN screen. Something like the Viewsonic vx2268wm has almost none (compared to CRT which has none)
