Try the MM mate. Some bargains to be had. I'm about to sell some gear and there's a lot of WC threads on there atm.
Cheers, will keep an eye open.
Cheers mate, was a bit nervous as it was my first build but went smoothly in the end.
Btw i have a IDE DVD rom/burner. Think i can still cable it via the back if i can get a cable long enough?
why don't you just grab a new SATA DVD burner for around a £10, stop you having a nasty ribbon cable in your case?
i cant seem to find the black/red version of this case anymore.![]()
In that case, DO EET!
I'm just waiting on a new CPU block for mine and i'll get some pics up.
That me put the beast together phew. I know your meant to take your time cause i wanted to do a neat job but it took 6 hours.
I had some difficulty with the screws. You gotta use the screws it says not just any that fit which i learnt the hard way. The H50 was a bugger as well.
Anyway everything worked first time though
Thanks to Chris for your input in temps and pics and everyone in discussion
My new temps are unreal.![]()
What temps you getting? i was hitting 62-66c max during BFBC2 on the cores(my idle is 45-48c though lol but with HT on) at 4ghz on my i7 920 in a warm room and GTX580 hit 70c max.Are these good temps by the way people? i do not like the idle temps much and no idea why they are a bit warm.....my voltage is 1.275 and i do not have speedstep on as it doesn't seem to decrease it when idle/browsing net.
I would have gone for a FT02B-W if there wasn't anymore of my current left.
I have to say Silverstone probably will be my only brand for cases now in future.![]()
Cant wait to see what you've done to my baby![]()
Just sent you a message.
FINISHED!
But turns out my PSU is shot. That's another 10 day turnaround :/
Also, dude, reckon you have any more of the hotswap connectors sitting about?
FINISHED!
