- 1 Jan 2011
Hi. I need some help with RAM choice for my new set up. I'm NOT an overclocker or gamer!! I will only be using the set up for digital audio mixing & recording & Video/photo editing, nothing else. So far I've decided on Intel i7 2600k & Asus P8h67 M-Evo Mobo (don't need dedicated graphics for what I'll be using it for). I have chosen to go for the 2600k instead of 2600 so I can take advantage of the HD3000 integrated graphics! As RAM is going to be important for my needs I need some help deciding how much & which sticks to choose. I don't want any less than 8gb & either 1333mhz or 1600mhz sticks will be fine (H67 mobo only supports 1333mhz max.), which ever is cheaper!! Firstly, should I go with 8gb (2x 4gb sticks) or 16gb (4x 4gb)?? I'm told I could never have too much memory for my needs!
I've been looking at the blue Corsair Vengeance & G skill Ripjaw/G Skill Ripjaw X. I am a little concerned about the height of the vengeance sticks but as I won't have a graphics card or need any cooling systems as not overclocking so only be using the stock heatsink for cpu, do I need to be concerned about the height?? I know there are the 'low profile' option but they are over budget & not needed.
I've seen the normal G Skill ripjaw & the ripjaw X-would both these sticks work well with sandybridge i7 2600k??
I've seen the Corsair XMS3 sticks at a good price too, would you recommend these with the i7 2600k?? Or are these sticks not the best for i7 SB?? My max.budget is around £100, maybe a few quid over.
Thanks in advance
Thanks in advance
